Ansys Learning Forum Forums Discuss Simulation General Mechanical Failed to Generate the rotation of masses Reply To: Failed to Generate the rotation of masses
peteroznewman
Hello Daniel,
Explain in more detail how these solid bodies are connected in reality. Show each inseparable assembly.  Show where those assemblies make contact with each other that allows separation and sliding. I see you have Forces C and D that point at each other. Are those supposed to represent some kind of nut and bolt that pulls those two holes toward each other?Â
