Ansys Learning Forum Forums Discuss Simulation Fluids Specific heat UDF energy imbalance Reply To: Specific heat UDF energy imbalance
adave12
I am not sure if OptiSlang would be the best option , because I am changing the mesh according to the geometrical change . i.e to maintain some element quality and skewness. Therefore some mesh independence as well .
So just to cover  the process . every single time I change the geometrical parameters , and initialise the fluent file , the variable fails to do so . However if I dont change anything outside the fluent workspace (i.e Geometry and Mesh) , it does not have a problem running and the variable value is changed seamlessly.
