Ansys Learning Forum Forums Discuss Simulation Fluids Specific heat UDF energy imbalance Reply To: Specific heat UDF energy imbalance
You may want to look at sets where the UDF is set. That also allows you to run some sets simulataneously. Otherwise Optislang may be your best option.
Replacing the UDF with an Expression looked vaguely possible but that seems limited to IF ELSE and not IF IF ELSE. Maybe in the future.Â
