Ansys Learning Forum Forums Discuss Simulation General Mechanical Ansys Aqwa Pitch Free Decay Reply To: Ansys Aqwa Pitch Free Decay
Shuangxing Du
It seems that these warning messages are not relevant. I noticed that the displayed unit of angle is in degree, so that the unit of the rotational motions' stiffness matrix diagonal elements is in [Nm/degree].
The NREL's values could be in [ Nm/rad].  Could you please compare these values again by setting the unit as rad?
