Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › AnsysWBU.exe encountered a problem… › Reply To: AnsysWBU.exe encountered a problem…
Gary_S
Ok. It seems the problem is with your actual model, or with your workflow.
Can you elaborate on:
"This message pops up every time I try to generate an imported file into the design modeler (from static structural). Any imported file wont generate and the Design Modeler closes.
