Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Two way FSI › Reply To: Two way FSI
April 18, 2024 at 9:33 am
Rahul
When running System Coupling and it stops running, the first thing to do is examine the output files for each solver to look for clues to what happened. For Fluent, look at the transcript .trn file. For Mechanical, look at the .out file. Also, look at the System Coupling log file, scl.
I recommend going over this tutorial in the Ansys documentation that shows a 2-way FSI simulation with Fluent and Mechanical. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/sysc_tut/sysc_tut_reedvalve_fluent.html
if this tutorial works well, consider checking your participant setups again to see if it is correctly defined.
