Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Two way FSI › Reply To: Two way FSI
April 18, 2024 at 9:27 am
Swapnil
NUMBER OF WARNING MESSAGES ENCOUNTERED= 0
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1
+——————— M A P D L S T A T I S T I C S ————————+
Release: 2023 R1 Build: 23.1 Update: UP20221128 Platform: WINDOWS x64
Date Run: 04/18/2024 Time: 12:28 Process ID: 2956
Operating System: Windows 10 (Build: 19045)
Processor Model: 12th Gen Intel(R) Core(TM) i7-12700
Compiler: Intel(R) Fortran Compiler Version 19.0.5 (Build: 20190815)
Intel(R) C/C++ Compiler Version 19.0.5 (Build: 20190815)
Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
BLAS Library supplied by Intel(R) MKL
Number of machines requested : 1
Total number of cores available : 20
Number of physical cores available : 12
Number of processes requested : 4
Number of threads per process requested : 1
Total number of cores requested : 4 (Distributed Memory Parallel)
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.5 for Windows* OS
GPU Acceleration: Not Requested
Job Name: file0
Input File: dummy.dat
Core Machine Name Working Directory
0 DESKTOP-1TN19PS F:\Two way FSI\_ProjectScratch\ScrDA12
1 DESKTOP-1TN19PS F:\Two way FSI\_ProjectScratch\ScrDA12
2 DESKTOP-1TN19PS F:\Two way FSI\_ProjectScratch\ScrDA12
3 DESKTOP-1TN19PS F:\Two way FSI\_ProjectScratch\ScrDA12
Latency time from master to core 1 = 2.043 microseconds
Latency time from master to core 2 = 2.096 microseconds
Latency time from master to core 3 = 3.560 microseconds
Communication speed from master to core 1 = 13728.96 MB/sec
Communication speed from master to core 2 = 14491.18 MB/sec
Communication speed from master to core 3 = 10225.86 MB/sec
Total CPU time for main thread : 1.2 seconds
Total CPU time summed for all threads : 1.0 seconds
Elapsed time spent obtaining a license : 0.3 seconds
Elapsed time spent pre-processing model (/PREP7) : 0.0 seconds
Elapsed time spent solution – preprocessing : 0.0 seconds
Elapsed time spent computing solution : 0.0 seconds
Elapsed time spent solution – postprocessing : 0.0 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
Sum of memory used on all processes : 17.0 MB
Sum of memory allocated on all processes : 5184.0 MB
Physical memory available : 32 GB
Total amount of I/O written to disk : 0.0 GB
Total amount of I/O read from disk : 0.0 GB
+—————— E N D M A P D L S T A T I S T I C S ——————-+
| RUN COMPLETED |
| Ansys MAPDL 2023 R1 Build 23.1 UP20221128 WINDOWS x64 |
| Database Requested(-db) 1024 MB Scratch Memory Requested 1024 MB |
| Max Database Used(Master) 1 MB Max Scratch Used(Master) 1 MB |
| Max Database Used(Workers) 1 MB Max Scratch Used(Workers) 4 MB |
| Sum Database Used(All) 4 MB Sum Scratch Used(All) 13 MB |
| CP Time (sec) = 0.984 Time = 12:28:25 |
| Elapsed Time (sec) = 2.000 Date = 04/18/2024 |
