Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Two way FSI › Reply To: Two way FSI
Swapnil
This file may contain appended logs from a sequence of runs, with the most
recent output reported at the end of the file.
Transcript output started: 2024-04-18 12:28:20
|                          Summary of Coupling Setup                          |
|                          Coupling Participants (2)                          |
| Participant: Fluent                                                         |
|    Type :                                                            FLUENT |
|    UpdateControls:                                                          |
|       Option :                                            ProgramControlled |
|    Region: artery_wall                                                      |
|       Topology :                                                    Surface |
|       Input Variables :                                        displacement |
|       Output Variables :                                              force |
|    Variable: displacement                                                   |
|       Quantity Type :                              Incremental Displacement |
|       Location :                                                       Node |
|       Tensor Type :                                                  Vector |
|       Is Extensive :                                                  False |
|       Data Type :                                                      Real |
|    Variable: force                                                          |
|       Quantity Type :                                                 Force |
|       Location :                                                       Node |
|       Is Extensive :                                                   True |
|       Data Type :                                                      Real |
| Participant: Transient Structural                                           |
|    Type :                                                             MAPDL |
|    UpdateControls:                                                          |
|    Region: System Coupling Region                                           |
|       Input Variables :                                Force, Force_Density |
|       Output Variables :                           Incremental_Displacement |
|    Variable: Force                                                          |
|       Location :                                                       Node |
|       Data Type :                                                      Real |
|    Variable: Incremental_Displacement                                       |
|       Location :                                                       Node |
|       Data Type :                                                      Real |
|                              Analysis Control                               |
| Analysis Type :                                                   Transient |
| Global Stabilization :                                                 None |
| OptimizeIfOneWay :                                                    False |
| AllowSimultaneousUpdate :                                             False |
| PartitioningAlgorithm :                              SharedAllocateMachines |
|                           Coupling Interfaces (1)                           |
| Interface: interface-1                                                      |
|    Side: One        |
|       Coupling Participant :                           Transient Structural |
|       Region List :                                  System Coupling Region |
|       Reference Frame :                                GlobalReferenceFrame |
|    Side: Two        |
|       Coupling Participant :                                         Fluent |
|       Region List :                                             artery_wall |
|    Data Transfer: Data Transfer                                             |
|       Suppress :                                                      False |
|       Target Side :                                                     Two |
|       Source Variable :                            Incremental_Displacement |
|       Target Variable :                                        displacement |
|       Unmapped Value Option :                                 Nearest Value |
|       Mapping Type :                             Surface Profile Preserving |
|       Convergence Target :                                         1.00E-02 |
|       Ramping Option :                                                 None |
|       Relaxation Factor :                                          8.00E-01 |
|    Data Transfer: Data Transfer 2                                           |
|       Suppress :                                                      False |
|       Target Side :                                                     One |
|       Source Variable :                                               force |
|       Target Variable :                                               Force |
|       Mapping Type :                                   Surface Conservative |
|       Relaxation Factor :                                          6.00E-01 |
|    Mapping Control:                                                         |
|       Absolute Gap Tolerance :                                      0.0 [m] |
|       Face Alignment :                                    ProgramControlled |
|       Poor Intersection Threshold :                                5.00e-01 |
|       Relative Gap Tolerance :                                     1.00e+00 |
|       Stop If Poor Intersection :                                      True |
|                              Solution Control                               |
| Duration Option :                                                   EndTime |
| End Time :                                                          0.2 [s] |
| Maximum Iterations :                                                     15 |
| Minimum Iterations :                                                      1 |
| Time Step Size :                                                 0.0002 [s] |
|                               Output Control                                |
| Output Control Option :                                            LastStep |
| Results        |
|    IncludeInstances :                                     ProgramControlled |
|    Option :                                                             Off |
| Write Initial Snapshot :                                               True |
| Warnings were found during data model validation.                           |
| Warning: Participant Transient Structural (CouplingParticipant:Solution 1)  |
|     has the ExecutionControl 'Option' set to 'ExternallyManaged'. System    |
|     Coupling will not control the startup/shutdown behavior of this         |
|     participant.                                                            |
| Warning: Participant Fluent (CouplingParticipant:Solution) has the          |
|     ExecutionControl 'Option' set to 'ExternallyManaged'. System Coupling   |
|     will not control the startup/shutdown behavior of this participant.     |
| The variable locations of force and heatflow variables for all Fluent       |
| participants are set to 'Node'. Make sure that this is consistent with the  |
| setup within Fluent. When importing the SCI file (this includes running     |
| inside Workbench), you can control the locations of these variables by      |
| using the 'SYC_FLUENT_CONSNODAL' environment variable. For more             |
| information, refer to System Coupling User's Guide.                         |
Awaiting connections from coupling participants...
Transcript output stopped: 2024-04-18 12:28:25
