Ansys Learning Forum Forums Discuss Simulation General Mechanical Disable Scoping Wizard Reply To: Disable Scoping Wizard
Sampat Kumar
Hi terryr1,
You can turn off this feature for this project, but it’s a very useful addition to ANSYS. It saves you a lot of time by automatically detecting lost scoping when you modify geometry parts in the space claim.
Please follow the following link for more details.
https://simutechgroup.com/preserve-geometry-associativity-in-ansys-mechanical/
I believe when switching to wireframe mode, you’ll have the option to click the green marks and uncheck the Scoping Wizard under the selection tab in Mechanical. Ideally, after clicking the green checkmark and exiting the Scoping Wizard shouldn’t permanently lock you in wireframe mode. If the program remains in wireframe mode or takes a significant amount of time to switch back to solid mode (shaded exterior and edges), then that would be a concern and it should resolve.
To bypass this issue of the scoping wizard sheet highlight, you can directly uncheck the “Scoping Wizard” option under the Selection tab but it will not turn off the geometry associative, for turning it off you can follow the option as Ankush suggested. This Scoping wizard option is just for highlighting and hiding the Worksheet for that particular moment.
Best Regards,
Sampat
