Ansys Learning Forum Forums Discuss Simulation Electronics Polarization and Angle of Incidence Scan with Floquet ports in ANSYS HFSS Reply To: Polarization and Angle of Incidence Scan with Floquet ports in ANSYS HFSS
Tenyu Aikawa
Thanks for the response, I guess I was thinking of the polarization in the sense of, if I rotated the TE mode around my metamaterial but in that case I would actually be doing a Theta-scan 0-360 degrees (assuming polar coordinates). Then also by doing a Phi-scan I could also control the angle of incidence along the z-axis from 0-90 degrees. So if I understand you correctly, we are actually changing the angle of incidence through the phase delay of the lattice pair boundaries instead of manipulating the floquet ports is that correct?
