Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Problem on Solar generation monitor settings › Reply To: Problem on Solar generation monitor settings
April 17, 2024 at 6:04 pm
Guilin Sun
When there are other materials with loss/absorption, different monitor size may cover different materials so the absorption calculated will be different. In your case, Please make sure that the monitor only covers the region where the absorbed light power can be converted into e-h carriers.
I would suggest to set larger monitor size along the periodic BCs, eg, extend it to the outside of the BCs.
