Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Modeling Combustion/Flameholder as a Pressure Loss in adiabatic flow › Reply To: Modeling Combustion/Flameholder as a Pressure Loss in adiabatic flow
April 17, 2024 at 2:46 pm
You may want to look at 2d axi-symmetric rather than just 2d, but I'll leave that for you to decide.Â
Porous Jump (surface) or Porous Media (volume) are the two pressure loss options. They both use resistance coefficients so may or may not give you want you need given the above formula: the theory is covered in the Fluent User's Guide, clicking Help in Fluent will get you there.Â
