Ansys Learning Forum Forums Discuss Simulation General Mechanical Insert Python Code object through APDL command sheet for batch automation Reply To: Insert Python Code object through APDL command sheet for batch automation
mrife
Yes; generally speaking we usually gather the result to an array (*VGET); open a file for writing (*CFOPEN); write the array to the file with a format of your choice (*VWRITE); then close the file (*CFCLOS).
