Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Geometry import causes “OnRefreshTransferData failed!!”-error › Reply To: Geometry import causes “OnRefreshTransferData failed!!”-error
Albert
I have found that when using Spaceclaim, you need all of your components and solids to have unique names in order to go into Maxwell properly.
I went into Spaceclaim and manually made all of the components independent, then renamed all of the solids to unique names.
Of course this broke the functionality of having components all be the same (when you change one, they all change), but it got rid of the error.
I feel like in older versions, Maxwell might have automatically renamed parts to prevent duplicate names when needed, but now it doesn’t and throws this error.
I found that this solved the problem for me with getting the “OnRefreshTransferData failed!!”-error
