Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Finding result of axial strain at a node in rebar › Reply To: Finding result of axial strain at a node in rebar
Sokpanha Mao
Thanks Yinghao Tian,
I tried to follow your suggestion. When I select the element, how can I identify the integration point? because I would like to select a node on the rebar to view the result on that node.
Best regards,
Panha
