Ansys Learning Forum Forums Discuss Simulation LS Dyna Finding result of axial strain at a node in rebar Reply To: Finding result of axial strain at a node in rebar
ytian
I am not 100% sure for the beams, but I think you can go to "EleTol", then "Identify", select "Element" (Integration point) and check "Show Results", and select the element(s) at your desired location.
