Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Energy conservation/balance in mixture multiphase › Reply To: Energy conservation/balance in mixture multiphase
Couple of suggestions from a colleague. Set the gas enthalpy as zero & liquid to suit; basically you just want to be worried about the latent heat as there are no reactions. Which multiphase model are you using?
