Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Stripline Coupler Design in HFSS › Reply To: Stripline Coupler Design in HFSS
Praneeth
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
It is understood that you are not able to replicate the response of your HFSS design in Circuit. Please check the response of your coupler in the circuit for linear network analysis to see if you are getting the same response in both HFSS and Circuit. If you are new to Ansys Circuit, then please go through this video for the step by step approach - Cosimulation Using Ansys HFSS and Circuit - Lesson 2 - ANSYS Innovation Courses.
Hope this helps.
Best reagrds,
Praneeth.
