Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › AQWA_linear damper problem › Reply To: AQWA_linear damper problem
Shuangxing Du
Fender only provides the restoring force and damping force when it is in compression. By using a pair of fenders with the opposite normal directions, it will be allways one of them in compression.
