Ansys Learning Forum Forums Discuss Simulation Electronics How to change excitation normal axis in Maxwell 2d? Reply To: How to change excitation normal axis in Maxwell 2d?
NKC
Jad Diab,
If you want to assign the current in the direction you are trying to then it becomes a 3D problem.
If your model is axial or radial symmetric then you just need to model the surface on the right side in the XY plane and define the model depth in the Maxwell> design settings.
If your model is not symmetric you cannot use Maxwell 2D.
Navya
