Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Issues getting analysis to behave as I would expect. › Reply To: Issues getting analysis to behave as I would expect.
Akshay Maniyar
Hi Rowan,
Can you check the initial information table and see if you have some orange or red-marked contacts? Also, can you try switching the weak spring OFF and see if your model is properly constrained?
It is better to use displacement constraint for the proper constrained model. You can apply displacement and check the reaction force for it.
Thanks,
Akshay Maniyar
