Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Meshing optimized lattice › Reply To: Meshing optimized lattice
Govindan Nagappan
See if you can use Layered tetrahedron or patch independent tetra.
For PI tetra, make sure you use appropriate sizes. See how the octree method works: Patch Independent Algorithm for Tetrahedrons Method Control (ansys.com)
You need to pick an appropriate mesh size for the method. Slice and mesh a small region of the geometry and then once you know the appropriate size that works, use that on the full model and see if it helps.
