Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Trouble with population balance for bubble column simulation › Reply To: Trouble with population balance for bubble column simulation
Thank you for the answer! I was away traveling, so please excuse my late reply.Â
Before I try to make a more refined mesh, I wonder if you think a polyhedral or a poly-hexcore created using fluent meshing should be sufficient for the simulation, or if I should try to improve the hex mesh I created using ICEM?Â
I think the bulk flow is behaving as expected. The water is flowing upwards above the spargers and is flowing downward/recirculated between the spargers.Â
Figure 1: Velocity of the column in the crosssection that goes through one sparger (see original post)
Figure 2: Velocity of the column in the crosssection that goes through the two spargers (see original post)
Figure 3: Velocity of water at a crosssection of the column at h = 10.5 cm
