Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Cycle to cycle simulation (multi-cycle) in ANSYS-forte › Reply To: Cycle to cycle simulation (multi-cycle) in ANSYS-forte
Ren
In a multicycle simulation, the global crank angle value for simulation limits will increase monotonically starting from the initial crank angle until it reaches the final crank angle. However, crank-angle-based timing parameters, such as spark timing, injection timing, and output controls, have the options of "cyclic" or "global". With the "cyclic" option, the timing will be repeated cyclically.
