Ansys Learning Forum Forums Discuss Simulation Electronics A possible bug was found in using of boolean subtract function Reply To: A possible bug was found in using of boolean subtract function
Praneeth Munaga
Hi Changming Song,
Here are the screenshots of the model. My apologies for getting back to you late, I had to recreate the model as we do not store the models.
I agree that "attach to original object" should be used for creating a parametric design.
If it helps, I have created the rectangle1 array first, then created the polygon2 array and then subtracted the latter one.
Hope this helps.
Best regards,
Praneeth.
