Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Air flow caused by heat source in closed volume › Reply To: Air flow caused by heat source in closed volume
Federico
if you share topology in SpaceClaim, then you would not need to set the boundaries as interface, as you will have wall/shadow pairs on any solid-to-any contacts.
If you do not have shared topology, then you can set these as interfaces but you would then need to create a Mesh Interface in Fluent for non-conformal contacts.
