Ansys Learning Forum Forums Discuss Simulation Fluids Finding Lift force in CG motion UDF Reply To: Finding Lift force in CG motion UDF
The CG_MOTION examples should cover the data use - basically the force will be calculated and then the motion assigned.
Regarding vel[1] values. At present it's uncertain if they're high because the maths you're using isn't quite right or if it's because the solver is diverging and that then returns a nonsense value to the equation which in turn causes the airfoil to move too far.Â
