Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ANSYS fluent – Rocky DEM coupling › Reply To: ANSYS fluent – Rocky DEM coupling
So the particle flow changed as you passed 220-230 rpm? I'm trying to understand if the direction is changing or if it's an optical illusion caused by the image refresh rate.
