Ansys Learning Forum Forums Discuss Simulation General Mechanical One or more entities failed to mesh. The mesh of the bodies containing these ent Reply To: One or more entities failed to mesh. The mesh of the bodies containing these ent
Aurojyoti Prusty
Hi Petter,
What is the error message you are getting while generating the mesh? Make sure the bodies are connected properly. You can refer the video link below.
https://www.youtube.com/watch?v=-cpyYpbNv8o&t=10s
Additionally, if there are small features on the beams that are not important for the analysis, you can use the "Automatic Mesh Based Defeaturing" option in Workbench Mechanical or Workbench Meshing. By setting a "Defeature Size" value larger than the size of these small features, the mesher will ignore them, simplifying the meshing process.
Thanks,
Aurojyoti
