Ansys Learning Forum Forums Discuss Simulation General Mechanical One or more entities failed to mesh. The mesh of the bodies containing these ent Reply To: One or more entities failed to mesh. The mesh of the bodies containing these ent
Sampat Kumar
Hello Petter,
What types of problems do you face while generating a mesh? Tell us about any errors you receive during mesh generation.
First, try using a global mesh to see which parts are causing problems. Then, apply local mesh controls to those specific areas and adjust the element size according to your requirements.
If small parts in the model are causing issues, use the sizing control and adjust the defeaturing size based on the size of those parts
Best Regards,
Sampat
