Ansys Learning Forum › Forums › Discuss Simulation › Photonics › How to calculate the mode volume in 2D PhCs structure? › Reply To: How to calculate the mode volume in 2D PhCs structure?
Amrita Pati
Hi Muhammad,
In FDTD simulation, we calculate the electric field first and then the mode volume is calculated using the equation. Are you using an analysis group to calculate the mode volume? If yes, you will see that there is a DFT monitor within the group that calculate the eectric field distribution.
Amrita
