Ansys Learning Forum Forums Discuss Simulation Fluids Need help with UDF. “999999: mpt_accept: error: accept failed: No error.” Reply To: Need help with UDF. “999999: mpt_accept: error: accept failed: No error.”
Zwernjayden
Its steady state. Would it be like this? Im a bit confused how the arguments for the F_PROFILE work. What does the i and the i+1 do? It says its supposed to determine which profile is which but I don't see a way to actually select it in the GUI.
#include "udf.h"
#include
DEFINE_PROFILE(combined_surface_and_mass_flow_profile, t, i)
    face_t f;
    real Ts, heat_flux, Hv, r, Ts_old, Ts_new, m_dot, error;
    int iter;
    begin_f_loop(f, t)
        if (THREAD_ID(t) == 6)  // Select fuel grain surface
            // Initial values and heat flux retrieval
            Ts = F_T(f, t);
            heat_flux = BOUNDARY_HEAT_FLUX(f, t);
            // Iterative calculation for new surface temperature
            Ts_old = Ts;
            iter = 0;
            error = 1;
            while (error > 1e-6 && iter < 10)
                Hv = 2033631 + 310000 + 1500 * (Ts_old - 298);  // Update Hv formula as needed
                r = heat_flux / (Hv * 754);  // Regression rate calculation
                Ts_new = 20557.188 / (8.314 * (log(0.01104) - log(r)));  // New surface temperature calculation
                error = fabs(Ts_new - Ts_old);  // Compute error
                Ts_old = Ts_new;  // Prepare for next iteration
                iter++;
            // Update the surface temperature profile at the face
            F_PROFILE(f, t, i) = (Ts + 0.1 * (Ts_new - Ts));
            // Compute mass flow rate based on the final regression rate
            m_dot = 754 * r;  // Use the same r calculated for temperature
            F_PROFILE(f, t, i+1) = m_dot;  // Assuming 'position + 1' is the correct slot for mass flow rate
    end_f_loop(f, t)
