Ansys Learning Forum Forums Discuss Simulation Electronics What is the difference between importing an IDF file and an ODB++ file in ANSYS? Reply To: What is the difference between importing an IDF file and an ODB++ file in ANSYS?
Flaming
Hi Tomas,
it is reasonable. ODB++ file should be imported into a PCB primitive Icepak object, while IDF can be imported directly. Here is a more detailed definition of IDF.
If you need more help regarding your sepecific files, please submit a service request and I'm happy to help you!
Best regards,
Joey
Intermediate Data Format (IDF) – IDF 2.0 and IDF 3.0
Board File (.emn, .bdf) - data on board dimension and component positions.
Library File (.emp, .ldf)- data on component sizes, thermal and electrical properties.
