Ansys Learning Forum Forums Discuss Simulation Electronics Measuring Inductance Using two Terminals – driven terminal solution Reply To: Measuring Inductance Using two Terminals – driven terminal solution
GioF
Hi Lexi,
Inevitably, any current flowing structure will contribute to the inductance calculation. HFSS calculated the closed loop inductance of the created structure.
A deembeding option is offered for terminal lumped ports, which removes the parasitic inductance that the ports are adding to your model. You can select each port and enable Deembed on the Properties window. You can find more information on numerically deembeding port inductance in HFSS.pdf help document - page 4404.
