Ansys Learning Forum Forums Discuss Simulation Electronics What is the difference between importing an IDF file and an ODB++ file in ANSYS? Reply To: What is the difference between importing an IDF file and an ODB++ file in ANSYS?
Tomas Black
 Hi Joey,
I did import the ODB++ file, however, by doing so, I found that only the PCB trace information was imported, and the other components on the PCB were not imported. If I import the IDF file, all components can be imported. Is this reasonable?
Best,
Tomas
