Ansys Learning Forum Forums Discuss Simulation LS Dyna Beam-to-Beam Contacts Reply To: Beam-to-Beam Contacts
Thomas Lowery
I am not have any success with this, I switched to using a mortor contact as suggested by the link.  What I expect to happen is that I have two simple rings made of beams, I fixed one under the other can turn gravity on and the top ring should fall and bounce off the fixed bottom ring.  But it seems no matter what I do they just pass thru each other.
*CONTACT_AUTOMATIC_SINGLE_SURFACE_MORTAR_ID
$#     cid        title
         1
$#   surfa     surfb  surfatyp  surfbtyp   saboxid   sbboxid      sapr      sbpr
         1         0         3         3         0         0         0         0
$#      fs        fd        dc        vc       vdc    penchk        bt        dt
       0.0       0.0       0.0       0.0       0.0         0       0.01.00000E20
$#    sfsa      sfsb      sast      sbst     sfsat     sfsbt       fsf       vsf
       1.0       1.0       0.0       0.0       1.0       1.0       1.0       1.0
*PART
$#        title
Ring 1
$#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
         1         1         1         0         0         0         0         0
*SECTION_BEAM_TITLE
Ring 1
$#   secid    elform      shrf   qr/irid       cst     scoor       nsm     naupd
         1         1       1.0         2         1       0.0       0.0         0
$#     ts1       ts2       tt1       tt2     nsloc     ntloc
     0.226     0.226       0.0       0.0       0.0       0.0
*PART
$#        title
Ring 2
         2         2         1         0         0         0         0         0
*SECTION_BEAM_TITLE
Ring 2
         2         1       1.0         2         1       0.0       0.0         0
       0.2       0.2       0.0       0.0       0.0       0.0
*SET_PART_LIST
$#     sid       da1       da2       da3       da4    solver
         1       0.0       0.0       0.0       0.0MECH
$#    pid1      pid2      pid3      pid4      pid5      pid6      pid7      pid8
         1         2         0         0         0         0         0         0
