Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Updating Outlet pressure to get desired inlet pressure › Reply To: Updating Outlet pressure to get desired inlet pressure
OK, so we start with an outlet pressure of 0 Pa. You run the model and get an inlet pressure. If I increase the outlet pressure by (for example 100,000Pa) what might I expect the inlet pressure to be? If you're not sure feel free to run the model.
