Ansys Learning Forum Forums Discuss Simulation Fluids Updating Outlet pressure to get desired inlet pressure Reply To: Updating Outlet pressure to get desired inlet pressure
OK, so what do you gain from altering the outlet pressure to find the inlet pressure?  You know the inlet pressure relative to outlet for a given mass flow. As an aside, for incompressible flows use a velocity inlet, it's generally more stable and can be slightly quicker.
