Ansys Learning Forum Forums Discuss Simulation Fluids Blast reaction Reply To: Blast reaction
Diri Li
The turbulence model I use is the standard k-e model, the combustion model is a finite rate/vortex dissipation model, the mixture is methane-air, the ignition temperature is set to 1800k, and I use SIMPLE's solution method.
