Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Reflected Mesh Refinement in Watertight Workflow › Reply To: Reflected Mesh Refinement in Watertight Workflow
When you're going through the workflow there should be an option for the size functions in Generate Surface Mesh. You may want to turn off proximity.
The surface you're meshing come from CAD. How does that look before you go into Fluent? However, if you're turning off the proximity sizing that may not matter.
