Ansys Learning Forum Forums Discuss Simulation Fluids Reflected Mesh Refinement in Watertight Workflow Reply To: Reflected Mesh Refinement in Watertight Workflow
robert reis
Thanks Rob, Some good points to look at and I will work through.
I am running the sims on a HPC remotely and just noticed in the transcripts I am getting turbulent viscosity ratio limit warnings.  At this stage I am using kW-SST steady while figuring out this mesh strategy.  I figure I'll have a look at the result files and mark the limiting cells and see what the go there is.
In the meantime two final questions:
  1. you mention "turning off" proximity - how do you do that in watertight workflow?
  2. There may be a simple answer to this and I just missed the important episode in season 1.... is there a way I can "separate" the vertical from horizontal as you mention?
Have a great day.
