Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Divergence detected during single particle deposition analysis › Reply To: Divergence detected during single particle deposition analysis
There are some courses in Learning, and if you click on Help then navigate up the system you'll find some tutorials in Rocky's Help. Semi-resolved is very new, so I'm not sure about tutorials at the moment. They're also application based as opposed to feature so you may need to check each one.
