Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LsTasc Not Start Running › Reply To: LsTasc Not Start Running
April 15, 2024 at 7:37 am
oyalcin
I don't have the job_command.bat file, I tried to run it manually as you suggested but I get the error below, I don't have experience about the command lines so please correct me if I did wrong, I shift+right click in the 0.1 folder and opened windows powershell then copied the line you wrote but I get this error
