Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › In the extrusion model, model penetration occurs. › Reply To: In the extrusion model, model penetration occurs.
Sampat Kumar
Hi
Please check if the pinball radius is greater than the gap between the body or not. If you run the simulation Auto time steping as programm controlled then you should change it to substeps and then run the simulations.
Best Regards,
Sampat
