Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › AQWA_linear damper problem › Reply To: AQWA_linear damper problem
r.abbasi
Thnak you for your response.
previously I found that we can put additional damping this way(with your guidance):
so what is the difference between this way and that way with two fenders as you suggest?
