Ansys Learning Forum Forums Discuss Simulation General Mechanical fluid-thermal-solid interaction post-processing Reply To: fluid-thermal-solid interaction post-processing
Sampat Kumar
Hello HB Z,
You should use the coupled field transient analysis to calculate the temperature and heat flux distribution with the applied fixed support. You can also get the temperature and heat flux distribution by using transient thermal analysis, but you will not have the option to apply the fixed support in this case. Please try to chose the analysis type according to your requirement.
Best Regards,
Sampat
