Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › x-t plot foe shock wave problem in Ansys Fluent › Reply To: x-t plot foe shock wave problem in Ansys Fluent
Ayushman Srivastava
I am using the DPM model to inject the particles. I selected “group type” and “no. of stream= 20.” and my study is “transient”. A micro-shock tube is used, and the driver section is patched with a high-pressure gas and the driven section is patched with a gas at atmospheric pressure.
I am facing a problem: “Whenever I run the simulation at the same condition, in each simulation, the particle velocity at the nozzle exit is different, and the particle is reaching at a different time at the nozzle exit.”
Also, in each simulation, the message in the console is " the reverse flow on 168 faces of pressure outlet-12." appearing after every time step.
Why is it so?
