Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non-Premixed Combustion PDF generation with 4th-order interpolation › Reply To: Non-Premixed Combustion PDF generation with 4th-order interpolation
hmanatunga
Hi Vijay,
Thanks for that. Original case was set-up just with the non-premixed model. I just retried setting up a fresh case by reading the mesh and setting up the non-premixed straight away without setting up anyother fluent settings. Sadly, I am getting the same error. Might be helpful to note that I am using 2022.r1. The cluster that I am running my simulations at hasnt been upgraded to the latest version yet.
Mana
