Ansys Learning Forum Forums Discuss Simulation LS Dyna LsTasc Not Start Running Reply To: LsTasc Not Start Running
igandiko
The command works for me.
In the picture you shared, you were selecting Intel MPI ls-dyna build without calling appropriate MPI exe, so it will not work. "LSDYNA.exe -dp" calls the SMP version and this should have worked. There is no other changes to the setup other than making sure the solver command is correct. LS-TaSC should have created job directories before running ls-dyna. If you don't see any directories, then maybe ls-tasc was not installed correctly. When you click "run" lstasc_script located in installation directory is called. Please check if this exe is available. If its there, try running the project in a new directory, maybe an older run was not "cleaned" correctly.
