Ansys Learning Forum Forums Discuss Simulation 3D Design Spaceclaim API C# – Generate Midsurface Reply To: Spaceclaim API C# – Generate Midsurface
Udeep Shah
Hello Devendra,
Thanks for the help, I was able to get the mid surface from C# code working. The only issue is that it sometimes generates a different midsurface for certain solids even though the min and max thickness ranges are the same. Is there a way to set the thickness tolerance for the API?
